Pulled the triger long tube headers
jljbtm
Ill be anxious to hear the results or gains. What will u do on the other end? CAI?
Sent from my Samsung Note 4
tcazes
5.7L
Make sure you order some o2 extensions or be ready to make your own. It's easy but just wanted to throw it out there lol.
Numnutz
Numnutz
Upstate New York
They sort of resemble a set of Kooks
I did notice that. Unlike the OBX the tubes aren't welded two or three piece, they appear to be one piece except for one. Like I said, I'll check the welds when I get them, if I have to touch them up it's no big deal. What I also noticed is, all the tubes seem to be the same length.
12sportmc
NC
What are you going to run for a Y pipe? Or are you gonna go ahead and make it a true dual set up? I'm definitely curious on the quality and fitment of these as well
huntergreen
Marine Corps Navy Badge
how hard would it be to run a true dual exhaust? tks
Metalizer
Pearland
These look great, I've been eyeing a set for a while. My only concern would be fitment with 4x4, steering shaft clearance and the quality of the hardware.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Numnutz
Numnutz
Upstate New York
Numnutz
Numnutz
Upstate New York
I'm going to start asking early.
Anyone know the torque pattern and the torque of the bolts?
Good chance you'll be tightening a lot of them with a wrench,so "good-n-tight" is the torque rating.I never did look up a torque sequence,i just did a circle pattern when I tightened mine.Starting in the middle and working my way out to the end ones.Mine have been on for 12,000 miles with no leaks and I've never re-torqued them,and that's with the poor fitting JBA's I have.
ramittome
Gonzales, LA
The other thing, Kooks seems to be the only one advertising 1 3/4", everything else is 1 7/8"
I'm actually pretty excited.
I have the stainless works long tubes and they are 1 3/4".
Is it just me, or are the "long tube headers" in this thread, short? And quite straight? I know my long tubes are about twice that length and turn down and back again.
Numnutz
Numnutz
Upstate New York
Pictures in the same thread?
Kooks do look shorter, man! I hope the fitment is correct.
ramittome
Gonzales, LA
Yeah, hoping they work for you. I just know it's tight under there, hoping the way they look straight are correct.
DILLIGAF
Canadian Forces
Canada
You'll need a tuner and custom tune to actually have real HP gains.
Even with O2 extenders the truck will run like ****. And Some still throw codes.
Numnutz
Numnutz
Upstate New York
DILLIGAF, I'm all set with the tuner and the Tuner (Jay Greene).
This guy is the best!
I never met a better man, he works with you from start to finish.
