olyelr
Or wait, that 8510 pounds isnt the tow rating, is it? Thats how much the truck can weigh/haul I think.
8,510 is the Gross Vehicle Weight Rating, or how much the TRUCK can weigh total. That is NOT the towing capacity. All references I can find on the web state the towing capacity of a Power Wagon as always been right around the 10,000 lb. mark over the years.
One thing to consider as well, load your truck up (just your truck) as you would pull with it and run it across a scale. I did the same a few months ago and was shocked to see that with just me and a half tank of gas, my truck weighs in at 8,300 lbs. I checked my original invoice and found it shipped at a tick over 7k. So taking me and the gas out, I’ve added roughly 1,000 lbs in gear and accessories that now has to be deducted from my already terrible tow rating.
Those rating also include specs for tires(size and PSI). At least with our trucks, we know the true limits. Guys that buy 2500s and have them lifted along with Tire changes are probably towing more than they safely can towNot exactly. If your tipping the scales at 8,300lbs that leaves you roughly 210lbs for a hitch weight assuming a 8,510 gvw.. Carry less gear and you can have more hitch weight. That still allows you the maximum trailer weight rating assuming it's still under the GCVWR. Your legal as long as you stay below the rated allowances for the following.
GAWR Front = Front axle weight rating (how much weight allowed on front axle)
GAWR Rear = Rear axle weight rating ( how much weight allowed on rear axle)
GVWR = Gross vehicle weight rating ( how much the vehicle can weigh, without a trailer, but including passengers)
GCVWR= Gross Combined Vehicle Weight Rating ( how much the total vehicle/trailer combo can weigh including passengers)
If you go over on any one of the above numbers your considered overweight even if all other numbers are below. Most pickup truck owners could care less about axle weight ratings between the front and rear axle. If your a commercial truck driver you pay attention to them.
What do you pull behind your Power Wagon for camping? How does the PW perform?
Check this baby out, https://www.msn.com/en-us/autos/ent...ions/ss- Sent from my iPhone using Tapatalk
$200KPower Wagon isn't really a tow rig but at a light 5000 lbs it would pull that fine. That's a pretty cool trailer. I'm sure the price tag would give you sticker shock though. Wonder what they are going for?
Definitely want to put some panels and battery packs in some day. Any info out there on an efficient setup for that?
That big winch in front of the coolers has a bit to do with it too I suspect.Power Wagons typically have a tow rating around 10,000 lbs. as compared to a regular Ram 2500 Hemi being around 14,000 lbs. tow rating. That difference is why people talk about a Power Wagon not being as good as a tow rig as other vehicles. However, keep in mind that 10,000 lbs. is a decent size trailer and it wasn't too long ago where most "3/4 ton" gas trucks were in that range for factory tow ratings. My last truck was an '03 Chevy Silverado 2500 6.0L gas, 4.10 gears, and all of the heavy duty and towing options and it had a factory towing rating of under 10,000 lbs. And in the end it's basically just "lighter" springs and the D-rated tires on the Power Wagon that cause this (correct me if I'm wrong, but every other aspect of the powertrain is the same...).
