Putco 60” rear blade on Power Wagon
Corvette427
PA
About 1hour install. Pretty easy instructions, all that is left is wire tying it up and out of the way.
I used the Clips rather than fix it to the painted surface. Only because the blade centered meaning up and down covers up the hole to drop your spare tire. Actually I remove the grommet that the crowbar slides into, it’s in my glove box if I ever need it I’ll clip it back in place.
Corvette427
Corvette427
PA
Whoops had to correct something, here’s a couple more photos.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Looks awesome, now time to ditch the factory yellow rear bulbs to match the nice 6K LED reverse.
madtrucker2016
New York-Staten Island
3.0 Hurricane twin Turbo
Installed on my Laramie with the y connector from Putco was not hard to install. I always get stopped now and people ask what brand of light it is on my tailgate. plus its warranted for 3 years on the part. Can not get any better.
Badger 13
North Idaho
2013 Dodge Ram 1500
I am very please with mine as well. I used the clips, but put a small shim behind the clips, this give me just enough depth so I didn't need to remove the grommet for the spare removal access. Plus the Blade has a little give in it to move slightly to access the hole. Looks very nice on your Power Wagon.
ttusomeone
Nashville, TN
Right!!!!
That looks good! I've seen these advertised and thought about getting them. I'm just still on the fence. Can you notice it being brighter at night when reversing? Any other benefits you've seen beyond the (hopefully) better visibility among other drivers when braking/turning and the "cool" factor of having the aftermarket light?
olyelr
Kewadin MI
it has more lumens then some led light bars people put on the front.... it must be A LOT brighter in reverse mode.
Corvette427
Corvette427
PA
I will have to see when the weather breaks. This truck doesn't go out in the winter (or when salt is on the streets). I will say it actually hard to look at directly (all colors). I really bought it to cause attention to these idiots playing on their phones when they should be driving / braking.
Why don't they pass a law to disable these phone until the car stops. sorry, little peev of mine!
I have T5 lights in my garage (very bright) and i could tell against the drywall that the white reversing light was on. It's bright!
