Question about Mopar skids, part#'s needed for 2014 RAM 1500 Crew Cab Express
ram1500rsm
Trabuco Canyon, CA
I don't have a rear crossmember needed to mount the Mopar 68089777AB skid to protect the transfer case, and i've ordered Mopar 82214497 to fix that, i think the 8221497 kit comes with another skid plate, so i'll have a 2nd skid laying around :), but wanted to confirm the kit will fit my truck ?
43985307921_72f1f890d0_h.jpg20180811_153426 by Wrangler RSM, on Flickr
2nd question, and the one i can't find anywhere, i bought the Power steering skid, Mopar 68200064AB to protect the power steering. i went to fit it in, but the rear crossmember where the skid is supposed to be bolted with nursets doesn't have any holes in it, only holes available are the ones for the front diff skid, which i've already mounted see pics below. could i order that Crossmember with the nutserts holes already in it?
The crossmember underneath the engine has the nutsert holes in there
43985307991_f5d0e180d0_h.jpg20180811_153406 by Wrangler RSM, on Flickr
But the other crossmember end, close to the oil pan, doesn't have the holes.
Is there a part number for this crossmember that will have the needed 2 holes to mount the Mopar 68200064AB ?
43985307631_95f712e06c_h.jpg20180811_153337 by Wrangler RSM, on Flickr
Thanks a lot.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Hello,
82214497 will fit a 2014 1500 and includes the cross member
For the PS skid plate I will need your VIN to verify production date. If it shows applicable you will need to order the hardware shown on the install sheet here http://starparts.chrysler.com/info/default/K6862042.pdf
-Benny
Thanks Benny, is there a way i can PM you the vin ? I don't see such option.
Also, i have the power steering skid, the bolts and the nutserts already, thanks so much for the visual, what i don't have is the crossmember with the 2 holes where the nutserts will be inserted. my crossmember only have the holes for the diff skid, but it's flat on the other side.
Thanks much.
Edited:
This is the crossmember i'm looking for, notice that one in the schematic you posted have the holes for the nutserts, whereas mine is just flat
43384751084_130093f370_b.jpgRear_Engine_Crossm_RAM1500_1 by Wrangler RSM, on Flickr
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Yes you can message me your VIN
Thanks,
Benny
Good morning Benny, sorry it took me this long, i started a conversation with you, which i believe will PM you ?
thanks a lot, i've added the vin number in there.
Let me know if i did it right.
kad
Hudson Valley, NY
5.7L HEMI
When you get the results, please do post them here. I also have a 2014 CC Express and I'd like the part numbers needed as well.
-K
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
-K
I'll report back, or Benny can post the part number for everybody to see, either way, eager to know the answer :)
AllMoparParts.com
- Benny
Preferred Vendor
All
All
PM received and I replied but basically your truck is not compatible with the Power Steering skid plate as per FCA's notes
Tech Tip Description: Do not install this component on 2014 and 2015 Ram 1500 (DS/DX) vehicles built before 4/1/2014. These vehicles were built with a Front Lower Control Arm cross member that is not compatible with this skid plate. This cross member doesn`t include the bolt attachment holes. Skid plates can be installed on vehicles built on or after 4/1/2014, if built with the a compatible Front Lower Control Arm cross member.
-Benny
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
^^that's nice, good job
Has anyone here installed the power wagon gas tank skid plate on their 1500?.....part number?
https://www.moparpartsoverstock.com...D-PLATE-Fuel-Tank-XEE/6911421/52121265AB.html
I'm thinking to buy that skid, but i don't know if i'll need another crossmember to mount it, somebody in the RAM forumz, installed it in his single cab RAM 1500, and in the pics he has, he shows two crossmembers, (52022046AE, which seems to be same crossmember that comes with the transfer case skid kit, Mopar 82214497) , and just one rail (which in this picture above are those 3 bar looking things right in front of the muffler, Mopar 52121534AA )
But i'm looking at my truck frame, and i don't see the spot with the double holes to mount another crossmember behind the crossmember i already installed for the TC skid, the frame already had the holes for that one.
See here
44405154382_a8313b2388_h.jpg2018-09-03_12-25-06 by Wrangler RSM, on Flickr
JB1
Houston, Texas
When installing that crossmember for the transfer case skid plate, are the holes already threaded?
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Yes based on the fact that the hardware included are threaded bolts only. No rivnuts etc...
-Benny
Reactions: JB1
redas
North D
HELLLO,
I have this crossmember bended. Is it a big deal ? Can I just level it or better to replace it ?
Thank you for help
AllMoparParts.com
- Benny
Preferred Vendor
All
All
I suppose you can leave it but it looks like it's somewhat close to your exhaust and can hit
-Benny
JustinRam1500
