Question about wiring headlights
jrs6494
South east Kansas
I just bought the Spyder CCFL HALO LED PROJECTOR HEADLIGHTS. Now my question is how to wire the halo's. I watched a video that said the common way is to the parking lights. But you can also hook them to a toggle so that they are on all the time or when you want.
Which way sounds the best and how would you hook up a toggle if that's what I do? Where is a good location for the toggle as well? I do plan on adding fog lights and several others and might to toggles with them as well. Any help is great. Thanks.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
If you want them on all the time with your parking lights........then splice them directly to that. The wires on the plug go ground, park turn, so - hook it to the black one and the middle one.
For a switch, you'd need to run wire into the cab, and mount a switch. I would ALWAYS run a relay then too, just in case. Trigger it from the switch, give it power directly from the battery.
J
jrs6494
South east Kansas
What kind of relay would I need? Not sure about these things. Point out the right equipment and I should be able to hook it up.
