Question about zone uca fitment
jhal
Dallas, Tx
I had my zone uca installed. I was looking at them today an the arm that is toward the front is very close to the strut mount lip(the thing that flares out)
Driver side has maybe a 1/4" of space between the arm an housing, the passenger side has less than 1/8". I don't think that it's actually rubbing or at least I don't hear it.
So my question it to others with zone uca installed. Is this normal? Do they all fit this tight? Thinking I might need to take it back to have them adjust something
JB1
Houston, Texas
They are side specific and may need to swap sides. The ball joints are not completely centered on the control arms. One side of the arm is slightly shorter than the other. The longer side should face the front of the vehicle putting the ball joint towards the rear. Make sure they installed them on the correct side.
Here is a picture of a driver side installed incorrectly.
J
jhal
Dallas, Tx
My ball joint is toward the rear. But on the picture you posted doesn't look like the metal flares out around the base of the strut mounting housing.
J
jhal
Dallas, Tx
This is the passenger side
J
jhal
Dallas, Tx
This is the gap on the passenger side
JB1
Houston, Texas
Hopefully someone else has an answer
J
jhal
Dallas, Tx
bump. Anyone else have know if this is good or bad?
kg93
AZ
if they are on the proper way, no issues driving, i wouldnt worry about it
jonathanhudaon
Hey guys what do you think of the zone uca's? Thinking of buying for mine but not sure if I should go with Zone, CST or Total Chaos
madrock
To me, it looks like it is on the wrong side but maybe they updated the design. I recall seeing more clearance. The shorter arm and ball joint should be closer to the door with the longer part of the arm closer to the front of the truck.
Mauzz
I vote Total Chaos (says someone with stock arms)... Where are you located? I've heard uniballs suffer some in heavy snow/salt environments. Kris probably knows better.
JB1
Houston, Texas
Icon also makes some and I think Fabtech does as well.
kg93
AZ
Do yourself a favor and if you live anywhere they use salt stay away from uniballs. You will need to put grease on them weekly and probably replace the uniballs every year or two as they will get pitted from the salt even with the grease. I've tone quite a lot a research on it lol
jonathanhudaon
Well I live in Labrador, we use a mixture of salt and sand on the roads over here in the winter, I have a 6" BDS suspension lift and a 3" body lift. Gonna throw on some 37 or 38's soon (as I only have 35's now) was thinking of upgrading to the uniballs
SSGart
