Question after Zone install
Williams3803
2012 Laramie Longhorn 4x4
So I got the zone 6 inch lift with 5 inch springs, rear fox 2.0 shocks, and bilsteins at 2.8 up front. I still have about an inch rake and really like the leveled look better. Is there any way to level it at this point?? I really couldn't find anything after searching the forum. Thanks guys. Measurements are 44.5 inches up front and rear 45.5.
Marciel
Guess that's the only drawback of not having a threaded coilover, not as much fine tuning in ride height.
Sent from my SM-N910V using Tapatalk
Williams3803
Williams3803
I don't think they make a cool over that can adjust that much though. I would buy them if I could find some.
Marciel
Fabtech and fox make ones specific for a 6" lift. I run my dirt logics really low in the threads but there is way more lift if I wanted.
reddevil78
5.7 he I
If the lifts brand new let it settle. Maybe you'll level out or be closer to your mark, and it won't look as noticeable.
Scgirardi
Find a fab shop and cut rear springs. Buddy at work had that done due to his zone lift having rake. It actually had more rake as time went on due to a lot less weight in the rear of the truck.
joshhhh
