Questions on secure gateway bypass
Jden45
Ohio
Quick couple questions on Secure Gateway bypass module and Innova Scanners. I purchased a Innova SD39 mainly hoping to be able to do simple OBD, OEM OBD, and some workshop tools (Bleed ABS Module, reset battery, and electronic brake service nothing major) on a couple different makes of vehicles. Hoping to be able to use it on my 2018 Ram 1500 also. With the purchase and installation of the KAOdTECH Security Bypass Madule will this be able to work like it would with all previous years?
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
With my kaodtech, security bypass cable, so far, I have been able to touch every module listed on alfaobd, read and clear codes, make modifications if necessary change parameters and download my engine parameters file and my transmission parameters file via HP tuners obviously from an unlocked PCM on a 2024 1500 classic.
Just my experience.
Snapper 60
Australia
Cummins 6.7
Hi Jden 45,
if you you have a few Rams and you don't wish to pull the dash out AutoAuth can help you start an account cost you $60.00 per year but you need internet to connect each time once you have it it will work on all Stellantis 2018 and up vehicles you own and your mates as well. Just register as an independent Tech. I register 3 weeks ago and cost me $80 AUD and works every time I have an Autel MP808TS . Just check your tool is compatible on their website the Tools website.
Heres the link https://webapp.autoauth.com/
RamDiver
Marlborough, Ontario Canada
2021 DS
Hi Jden 45,
The KaodTech Security Bypass cable connects directly to the CAN bus blocks, beside/behind the OBD2 connector.
Removing the panel under the steering column which has 2 screws is the only removal required.
No need to dismantle the dash.
The entire installation might have taken me 10 minutes because I'm somewhat picky about wiring jobs. :cool:
