Radio Button Control Swap
Remen
CA
3.0L Diesel
I received and installed the steering wheel rear cover with volume/channel buttons and wiring harness the end of August. I just didn’t want to keep switching hands on the steering wheel to adjust the volume so I decided to address this issue. Other post cover steering wheel removal so I won’t go through those steps.
This is the original location of the buttons, different part numbers.
619FFB1E-AABB-46EC-AA4C-EAD916702C06.jpegI removed the buttons to modify the back covers so that mounting will allow correct orientation on the steering wheel back cover. The harness connectors can’t be swapped since the buttons control functions are different. You can see the red and brownish wires piggybacked so the control function is from the buttons. I also marked the circuit boards with a dot to make sure I kept the volume and channel up locations at reassembly.
I notched the opposite side of the button covers so that after installation the buttons were in the correct orientation. The buttons will not mount on the rear cover without the notch. Notice the red dot on the unmodified cover.
Here are the modified control buttons and wiring harness re-wrapped with Tesa tape. You should notice that the connector wires are now on the other side of the buttons. This keeps the circuit board mounted right side up, otherwise, controls functions would be reversed. Labels reapplied. Note: If you choose to remove the labels do so only after you separate the back button covers by applying heat with a heat gun for a few seconds. Don’t want to damage the circuit boards. Labels do not need to be removed. CF4685AB-2281-4CCE-9B10-298835A9B7A9.jpeg
R
Remen
CA
3.0L Diesel
Rear cover ready to mate with the steering wheel and front cover then reinstallation.
Make sure the control button wires are not pinched when you snap the front and rear covers together.
R
Remen
CA
3.0L Diesel
Installed the steering wheel and tested the control button functions. All tested as desired and I can adjust volume on the left and channels on the right. Much more comfortable, for me at least.
Guido2112
I guess I was lucky when I bought the upgrade kit to make my Express have the steering wheel controls.
After I put it all back together, The volume was on the left side and channel on the right (I guess something in the pigtail must be reversed). The buttons were upside down (up was down, down was up) but I just flipped the switches without having to take the wheel back off so it all works correct.
Naldo1710
So essentially you only notched the button back plates so that they can be placed in the opposite side correct? What about the harness? No modification there? Is the picture you showed only to illustrate that the harness is piggybacked from factory? I might attempt this later today. Thank you!
R
Remen
CA
3.0L Diesel
That is correct. Make sure the buttons are installed in the back steering wheel cover as shown in the last photo.(I reapplied the labels right side up). Harness is just as received from AllMoparParts.com, no modifications. I just detailed the discovery process and solution.
R
Remen
CA
3.0L Diesel
My steering wheel back cover had the buttons factory installed so the initial installation placed the volume on the right side. When I tried to install the volume button on the left side it popped back out because the notch was in the opposite corner of the back cover.
duckman631
New Jersey
2016 Big Horn Crew Cab
Hemi 5.7 K&N Cold Air Intake.
I wish I could put volume on left along side the channel change buttons.
enolS
NE Ohio
And here I thought it would be a simple setting on the radio. Nice work!
Naldo1710
Did it today. Fresh installation and moved the volume to the left. I'm loving it.
Sent from my SM-N950U using Tapatalk
R
Remen
CA
3.0L Diesel
Glad you made it happen, I feel the same.
KC Cryptkeeper
KCMO
2015 Ram1500
Now if we could reprogram the channel select buttons to work where I could scan up and down on my favorites and the middle button be to do the general scan.......
Naldo1710
You can, but only with an aftermarket radio and the maestro interface. Then you can use a laptop to setup all the button functions.
KC Cryptkeeper
KCMO
2015 Ram1500
Sounds cool but I would be happier if I could do it with my AlfaOBD software that I already own.
billiards4me
Just for future reference, for anyone wanting to do this in an alternate way... check out the PAC BCI-CH41 module. On amazon for $170, and it’s pretty plug and play into the back of the radio. It opens up some configuration features that are pretty sweet... one of which, is to swap the buttons on the rear of the wheel. You can do just the up/down swaps from side to side, and/or the center button swaps.... independently. Pretty nice setup.
KC Cryptkeeper
KCMO
2015 Ram1500
More reason that Alfa can do this......
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
It can't. It just turns things on/off.
The PAC unit, like similar units is intercepting the CANbus messages and sending out different ones for the desired outcome.
M² Mods.
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Going to do this upgrade, really miss them from my 2002 SLT.
Just found the complete kit, Genuine Mopar Steering Wheel Audio Control Upgrade Black, over at all mopar parts for under $65 including shipping!!
aimcgma
