Getting ready to replace the shocks/struts in my 2015 with factory raised ride height. Anyone know how the factory lift is achieved?
What are your ground to fender measurements?I was curious to this as well. My build sheet shows "raised ride height. " And yes, I know it's because of the 20" wheels. But front to back, what extra height? An inch from what I've read?
Front 39.25/Back 39.5
Nope,new. There is not a leveling kit in it. That's why I'm thinking taller springs maybe?Wow that seems really high. The factory right height is achieved by different springs that’s why the heights are all over the place. Most factory heights are in the 36” range and the “raised ride height” option is normally 1” higher so most measurements land in 36”-38” range
Did you buy used? A previous owner may have installed leveling blocks. Hopefully @512RAM will post his measurements
275/60/20It definitely has taller springs with the raised ride height option. What size tires do you have on it?
Front 36.5Wow that seems really high. The factory right height is achieved by different springs that’s why the heights are all over the place. Most factory heights are in the 36” range and the “raised ride height” option is normally 1” higher so most measurements land in 36”-38” range
275/60/20
Looks about right from the the heights posted so far. It's a common factory option...no unicorn.Hopefully some others chime in your leveled from the factory? You may have a unicorn
Did those have the option?Two guys posted 36.5” you posted 39 1/4” ? You’re claiming you’re over 2” higher than others the one confirmed he has the raised ride height option.
Yes. I'm looking at my build sheet.Did those have the option?
