Ram 2018 Air suspension
Wim Desmet
Belgium
Guys,
Does anyone know where to find a kit to lower the stock air suspension ?
I know there is a small kit.
Tnx
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Guys,
Tnx
Um, I know they make those aftermarket links but depending on how much lower you’re wanting to lower it, you’re probably gonna be bouncing the suspension off the bump stops a whole lot more.
Wim Desmet
Wim Desmet
Belgium
well I search for that aftermarket stuff, I don't care about bumping :)
Any chance you know a supplier?
SoCA Cameron
Norco
I am also looking to lower (4/6 Drop) my 2017 Limited with factory air ride. I have called Inez and Moe Performance. Neither have a kit (or solution) that support the factory air ride. I am looking to lower more than what the adjustable links provide.
corneileous
Podunkyville, OK
I honestly don’t know. That kit I linked is all I’m aware of, just short of converting to a spring ride or selling that truck for one that don’t have air suspension.
SoCA Cameron
Norco
Thanks, it looks like that kit will give me 2 to 2.5 inches, but when its that low the ride is like its sitting on the bump stops. Maybe I can just relocate the sir spring mounting points and just have some fabrication done.
corneileous
Podunkyville, OK
Yeah I know, that’s what I told that other person. It’s almost not even worth it to use that kit unless you’re ok with your truck riding like some hooptie on hydraulics that has no suspension at all. Lol.
But the back might be easy to fabricate some brackets but because the front uses a strut, I have no idea how you’d relocate that, or even set it up to where it’s top mounting point is higher, or the lower mounting point lower- and keep your front suspension geometry the same.
SoCA Cameron
Norco
After some research, It looks like I can just replace the airshocks/springs with shorter ones and use the normal 4X4 4/6 drop kit. Ridetech has the shorter airssprings
corneileous
Podunkyville, OK
Guess I don’t know which system you were looking at but the stuff I saw on their webpage didn’t look like it would work with the factory air ride system. Which kit you lookin at?
corneileous
Podunkyville, OK
Isn't the factory air suspension adjustable for ride height?
It is, to a point. You got entry/exit mode, normal height, aero mode, off-road one and two.
