Ram 2019 Classic RA2 to RA4 Upgrade
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Why doesn't your 14 radio show a hu part number and serial number, or SW version? ... Strange
I honestly am not sure what the pink connector is since it was never hooked up on the 13-15 radios and they removed it on the 16-17 radios (we thought it was a separate GPS antenna input). But it's back on the 18 radio and connected (on my factory 18 UAS) and there's also an extra red connector.
My 2018 truck connectors and UAQ with the mystery Pink connector. Maybe @00R/T knows (I can't verify it from a schematic/connector info) ...
WileECoyote
WileECoyote
Charlotte, NC
HEMI 5.7
Here is the system info. I think I took those pictures right after I turned on the truck and they hadn't filled in yet. (it takes a minute or so before they show up)cbac2a5f4013807de03b5584f6ef4366.jpgbc0bb4cd289939f7e4c19e132c586863.jpg
Sent from my Pixel 3 using Tapatalk
18harvest
huntsville
the pink plug is a gps plug .why i have no idea but on my truck 18 with uaq the pink connector harness is about 12 inches long and goes to a gps antenna attached with to screws to the bracket you have to cut out to install a double din radio.
Mpgrimm2
Preferred Vendor
SC
5.7L
Removed the 17 Ra4 from my 2018 Laramie after 3 days off use with no errors. Must be a setting somewhere or something with having the Sharkfin antenna & correct 2018 mirror that lets it work in a 2018 truck that came with a factory 8.4 UAx radio..
M² Mods.
WileECoyote
WileECoyote
Charlotte, NC
HEMI 5.7
I finally found a 2018 RAM mirror (68342283AA) reasonably priced. I installed it last night . Still getting the error. Next step is to try a shark fin antenna. Really nothing else left?
Mpgrimm2
Preferred Vendor
SC
5.7L
Thanks for the info. I snapped a picture of the GPS location & Cable PN (68334879AA) for anyone that wants it on my 2018 Laramie while I had the radio out. You can also see the security module.
Mpgrimm2
Preferred Vendor
SC
5.7L
Thanks for giving it a shot. If you get the sharkfin & extension cable, you shouldn't have to pull the headliner down just to test the sharkfin, just plug it in and sit it on the dash.
Nothing else I can think of, except some setting that is being overlooked in the BCM (maybe not shown w/AlfaOBD).
WileECoyote
WileECoyote
Charlotte, NC
HEMI 5.7
WileECoyote
WileECoyote
Charlotte, NC
HEMI 5.7
Mike, do you still have the 2017 RA4 VP4-NA radio? I would be interested in trying it to see if it works without issue.
WileECoyote
WileECoyote
Charlotte, NC
HEMI 5.7
One last thing I'm going to try, I ordered the pink cable 68334879AA (it was only $14.00).
If this doesn't work I think I will just live with the error :)
Butkis
Prosperity, SC
I recently replaced my RA2 with an RA3.I installed the radio bezel ( the one that is not ATC). After all of the installation, my auto headlights stay on continuously. Now, I can turn off my lights, however, if I were to leave the light dial on auto as I generally did, the lights will stay on day and night. I replace the sun sensor, thinking that might fix the issue, but it has not. So, my final thought on the issue is that it must be a residual issue with the rear view mirror. I do not have the auto dim mirror (manual) and no 911 assist(although I intend on getting one and seeing if that will cure the problem. if that does not do it the I suppose I could have gotten a bad sensor. Has anyone had this problem? if so, how did you fix it/ I sure could use some help.
18harvest
huntsville
i don't think the cable by itself is going to do anything.it goes to a gps ant. not all ra3 or 4's even have the pink connector.the ra4 i am using in my 18 now doesn't have one .and no 911 code.my truck was a factory uaq truck. i've seen a bad air card throw the mirror code.but it seems several people have had the mirror code problem with a retrofit so i would say maybe not the problem.the only other thing i can think of is the uax sales code missing in the bcm.
Mpgrimm2
Preferred Vendor
SC
5.7L
Just saw this. I sold the 17 Ra4 VP4-NA I had but have another one on the way for an upgrade kit. I really don't think the 17 radio will make a difference for you (vs an 18 radio) but email me if you want to pursue it and we can see if something can be worked out.
M² Mods.
WileECoyote
WileECoyote
Charlotte, NC
HEMI 5.7
A few weeks ago I would have agreed with you, but I found this article outlining the pink connector as a Cell Phone Diversity plug (http://www.wk2jeeps.com/wk2_radios_2014.htm) I think it is intended as a 'backup' in case the purple cable or antenna fails? So I thought maybe the message I am seeing is because there is nothing plugged into the pink connector? Worth a try :)
WileECoyote
WileECoyote
Charlotte, NC
HEMI 5.7
M² Mods.
Thanks, but I will see how this new cable works out. Otherwise I will just live with the error. Its no big deal...
WileECoyote
WileECoyote
Charlotte, NC
HEMI 5.7
I have an extra 2016 mirror with mic's if you want to try it. PM me if you are interested...
Orca
