Ram 2500 towing?
MEDLERHED
6.7L
I have a 2012 Ram 2500 SL. I'm looking at a fifth that has a GVWR max capacity of 14200. The dry weight is 11497 but with my cargo I'll be around 13k to 14k. My question is will the Ram I have be enough truck? By the way, first fifth wheel trailer, very new to me. Thanks for the feedback.
mowin
upstate ny
2017 3500 SRW
6.4 hemi
Will it pull it? Absolutely. Will you be over your payload #'s? Absolutely.
The pin wt of that 5er loaded will be around 2500 lb. Add the 5er hitch, family, and other stuff and your over.
The 6.7 is more than capable of dragging it all over, but IMO your in 3500 territory.
Juvenator93
My 15' 2500 with the 5.7 Hemi and 4.10 gears moved this 11,000lb load like a champ84cd8c70b269f5886d4b1036508b6222.jpg
14hemiexpress
6.4l
Need to know more about your truck. 2wd, 4wd, reg cab crew mega what engine and gear ratio? Fifth wheel is usually alot for payload on a 2500 but the 2500 is the most underrated truck on the market. Some.good airbags and you should handle the load just fine but you have to keep in mind over your weight limits is illegal reguardless wether you add bags or not. My .02 a 2500 with bags is no different than a 3500 srw other than the legal side of it.
mowin
upstate ny
2017 3500 SRW
6.4 hemi
Equipment trailer and a 5er are two different critters. Yes wt wise he's ok. It's the payload he get light on. The 6.7 is a heavy motor. In identical 2500's the 5.7 or 6.4 will have more payload then the 6.7.
My 3500 6.4 SRW has a payload just shy of 4k. My 5er has a loaded wt of 14k, pin WT of 2700.
spoon059
Just north of Washington DC
6.7 CTD
You will likely be over your listed payload, which is probably around 2300 lbs. That being said, you will be way under your rear axle rating. Your truck will handle the weight just fine if you chose to pull this trailer.
What makes it "illegal"? There are two things that make you "legal" when it comes to weight.
The most important is federal bridge weights, which I believe are 20,000 lbs per axle. I don't think the OP will exceed those ratings, and even if he tried I don't think his truck would be able to move that weight. Under the federal bridge weight limits, perfectly legal on that point.
The second thing is your registered weight. You can legally haul any weight you want, so long as you are registered to carry that weight. In Maryland, vehicle weight classes are 7000 lbs or 10,000 lbs (amongst others...). I had a 2010 Tundra that was rated by the manufacturer of 7200 lbs. I could either register for 7000 lbs and "lose" 200 lbs of payload, or register for 10,000 lbs and "gain" 2800 lbs of payload. So long as the OP pays to register his truck for the amount of weight he is carrying, perfectly legal on that point.
The number assigned to the truck by the manufacturer is arbitrary. They are a compromise between marketing, engineering and legal departments. They are not legally binding in any way, shape or form.
glsander
