ram oil pressure and system leak
bilmetropolen
5.7hemi
Hello people! I have got a problem with a dodge 1500 from 2007 with 5.7hemi
First, the oil pressure code: P0524
We have tried new oil and filter, testrunning with longlife, and putting new oil.
And second problem
Evaporative Emissions System - Small leak detected
OBD-II Trouble Code: P0456 Evaporative Emissions System - Small leak detected
OBD-II Trouble Code: P0440 Evaporative Emission Control System Malfunction
We have tried with a new EGR-valve, still no success.
Anyone got any ideas? Are there any known problem with this dodge regarding these codes.
//Bilmetropolen in sweden
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The evap codes are prob from the lines coming from the canister. Slide under the truck and look at the evap box and the lines coming from it. The only other thing that is common to throw those codes are the fuel cap either being faulty or not being sealed fully. Far as the motor goes when did the oil pressure issue start? Has the truck been yours since it was new? Any leaks you can tell?
quietpeen
2021 TRX
Hellcat
welcome To Ram Forum
Arturo Rojas
