TomB 1269
- Mar 27, 2019
- 452
- 454
- Location
- Schenectady NY
- 2019 Classic
- 5.7 Hemi
I have heard over torquing an issue since the motor came out years ago. As for heat and time, it should not cause the cracking, however they are not adding in the 3rd factor for these.
Regular activity, as in routine oil changes!!!!
If I had one of these engines and it cracked I'd be all over them. It is also one of the reasons that I have started taking my vehicle under warranty to the dealer for oil changes, and most likely will once out of warranty, particularly if I hear of any common issues, such as this.
Heat and age will cause any plastic to become hard and more susceptible to cracking. So it may have not been the mechanic today that directly caused it, but the mechanic 2 or 3 years earlier that stressed it. In any case, FCA needs to take responsibility for this issue as its a defect in part design. Just as cam failures on the Hemi, just like Ford had to on the spark plugs for the 5.4 3v tritons. However, it's gonna take lawyers, NIHTSA, and a couple of vehicle fires. Which by the way I am amazed have not been more common with as prolific as this issue seems to be. But then again, it could also be more time then heat that truely does these in, i.e. the oldest ones maybe the ones failing the most.
