RAM RADIO WIRING SCHEMATIC
Zachary J Burman
michigan
5.9l
Hello All
New to this forum. My name is Zach and i need a wiring schematic for a club cab radio wiring diagram as the previous owner of my truck had someone do a sketchy wiring job and I am trying to work out getting it all fixed so I can install a new radio and speakers. Would anyone have one or know where to get one?
Thanks in advance
Spike95
Houston
It’s in the service manual. I believe there are copies available here on the forum.
ViolentMouse
San Diego
5.9 magnum
1999 Dodge Ram Pickup Stereo Wiring
Constant 12V+ Red
Switched 12V+ Red/White
Ground n/a
Illumination n/a
Dimmer Orange/White
Antenna Trigger Yellow
Antenna Right Front
Front Speakers 6" x 9" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 5 1/4" Side Panels
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
06MegaRam1500
Connecticut
I am trying to install an after market radio but cant seem to find an explanation to what my wire colors are. The numbers are the locations in the harness:
1- gray/red
5- white/orange
6- white
7- gray/yellow
8- gray/blue
9-green/blue
10- green/yellow
11- black/green
12- gray/red
18- gray/lime green
19- gray/green
20- green/white
21- green/lime green
22- black
Can anybody help?
nathan_h
Nevada
Cummins
1- gray/red
5- white/orange
6- white
7- gray/yellow
8- gray/blue
9-green/blue
10- green/yellow
11- black/green
12- gray/red
18- gray/lime green
19- gray/green
20- green/white
22- black
Can anybody help?
Not sure if you solved this already but I found this diagram during my searching. (I was trying to figure out if the dash speakers which are tweeters get a full range signal…….because if so that would be a recipe for disaster if I put my tweeter in there and it blows!)
foxtail
canada
Anyone trying to get into this site get conncection error, drop your vpn if you have one. Or add it to the allowed list in vpn. Will not access with vpn on...
