HELP: Shock Sensor installation
TootoosisJohn
Saskatoon, SK
Cummins 6.7L
I need the wiring schematics for the driver's side door alarm. As in which wire is the one that triggers the alarm system when the door is forcibly opened?
I've done it before my other Dodge but it's pretty straightforward as it was an older model this is a 2023 Dodge Ram 3500 5th gen with a 6.7.
All I want to do is tap into The Wire with the shock sensor so that if the shock sensor gets triggered it will set off the alarm.
I know it's possible as I've done it before there's just so many damn wires I'm just hoping somebody has a schematic or diagram
