Ram Rebel Conversion Parts
AllMoparParts.com
- Benny
Preferred Vendor
All
All
We have been getting alot of inquiries for Rebel specific parts info so I have started this thread with links to popular requested parts. Please feel free to reply with a request and I will add it to this list.
Front Bumper Parts
Outer Bracket Kit https://parts.allmoparparts.com/oem-parts/mopar-bracket-bumper-68271501ac
Inner Bracket Kit https://parts.allmoparparts.com/oem-parts/mopar-bracket-bumper-68271506ab
Lower Bracket Kit https://parts.allmoparparts.com/oem-parts/mopar-bracket-bumper-68271516aa
Bumper Closeout Kit https://parts.allmoparparts.com/oem-parts/mopar-close-out-bumper-68271570aa
Bezel Kit Lamps https://parts.allmoparparts.com/oem-parts/mopar-bezel-bumper-68271564aa
Bezel Kit Tow Hooks https://parts.allmoparparts.com/oem-parts/mopar-bezel-tow-hook-68271565aa
Lower Grille https://parts.allmoparparts.com/oem-parts/mopar-grille-lower-68271566aa
Front Bumper https://parts.allmoparparts.com/oem-parts/mopar-bumper-front-5sx95rxfab
Left Headlamp Filler https://parts.allmoparparts.com/oem-parts/mopar-filler-molding-55372919ad/?c=aT1USDEzMDA1NSZyPTI=
Right Headlamp Filler https://parts.allmoparparts.com/oem-parts/mopar-cap-front-bumper-upper-55372918ad
Bracket Kit https://parts.allmoparparts.com/oem-parts/mopar-bracket-hider-panel-68340904aa
Lower Bumper https://parts.allmoparparts.com/oem-parts/mopar-bumper-front-5sx96jscac
Left Brace https://parts.allmoparparts.com/oem-parts/mopar-brace-front-bumper-68253755aa
Right Brace https://parts.allmoparparts.com/oem-parts/mopar-brace-front-bumper-68253754aa
Left Splash Shield https://parts.allmoparparts.com/oem-parts/mopar-shield-wheelhouse-55112807aa
Right Splash Shield https://parts.allmoparparts.com/oem-parts/mopar-shield-wheelhouse-55112806aa
Left Splash Shield https://parts.allmoparparts.com/oem-parts/mopar-shield-wheelhouse-68251641ab
Right Splash Shield https://parts.allmoparparts.com/oem-parts/mopar-shield-wheelhouse-68251640ab
Left Front Fender Flare https://parts.allmoparparts.com/oem-parts/mopar-molding-wheel-opening-flare-1fv91rxfae
Right Front Fender Flare https://parts.allmoparparts.com/oem-parts/mopar-molding-wheel-opening-flare-1fv90rxfae
Fog Lamps (2 required)
https://parts.allmoparparts.com/oem-parts/mopar-fog-lamp-assembly-55112827ab
Front Grille Assembly
https://parts.allmoparparts.com/oem-parts/mopar-radiator-grille-5uq43rxfab
Rear Bumper (Powder Coated Black with Dual Cutouts & Park Sense)
Rear Bumper https://parts.allmoparparts.com/oem-parts/mopar-bumper-step-68271591aa
-Benny
  • 4th gen Rebel Front Bumper.pdf
Uaintlo
How about for some of the Rebel interior pieces that are trimmed in red?
I am mostly looking for the left and right ac vents,
(I found the center ac vents/ radio stack on ebay)
and is it possible to get the top of a 2016 console with the red around the cup holder area?(not looking for the leather lid with the stitching,I already have that)
probability crazy to ask this.. but is there any way to get the top dash pad with the stitched edge on it?!
thanks!
John
AllMoparParts.com
AllMoparParts.com
- Benny
Preferred Vendor
All
All
I continually check the interior parts but many part numbers are missing from our dealer data. Once Mopar decides to add this I will add it to the first post under an Interior section.
-Benny
AllMoparParts.com
AllMoparParts.com
- Benny
Preferred Vendor
All
All
@AllMoparParts.com can you make a list of the parts that one would need to do a ram rebel conversion. 2015 ram 1500 to the rebel.
Hello,
The appearance list is posted above but there are some unanswered questions as to the hardware needed. Our data does not specify quantities accurately. Let us know what else you may be looking for.
-Benny
MaxSteel2013
Benny - this is awesome that you put this together. Can you post a link to the stock fogs too? I'm picking this conversion over any aftermarket bumpers.
O.R.T.
Wessyyydddeee
Benny, I still haven't had the time to cross-compare the front suspension pieces compared against the other year 1500's, like say my 2014 4wd QC, but the parts from QC to CC on this year are same part numbers.
Can you please take a look and let me know either privately or via reply here what the part number listing is, if there are differences as far as left/right and list the changeover parts?
L/R Upper and Lower Control Arms.
L/R Spindles.
L/R Tie-Rod Ends
L/R Tie-Rod inners (Electric Steering).
Also, if the Steering Rack and Front Differential Center mount standard or w drop-brackets?
The reason I ask this specific bit is the 2014 still came with those problematic upper ball joints that like to pop loose and if everything is a simple bolt-on affair the change to the standard (Non-Air) font suspension could be kept factory. ;)
Shane
MaxSteel2013
L/R Spindles.
L/R Tie-Rod Ends
Shane
Are you going all out Rebel? Shouldn't be a difference in control arms for a Rebel conversion. Only added air suspension.
O.R.T.
Wessyyydddeee
*Hopefully.* ;) There has to be at least a minor difference in p#'s even if my example was a late-year 2014 Big Horn and the 2017 Rebel upper arms. FCA did away w the style of upper arm my truck has. I included the rest of a standard suspension swap kit just in case. Benny will get what I mean. If it's just the upper arms cool, but I don't have access to the full OEM list since I'm not at a dealership anymore.
MaxSteel2013
I have my 2017s in a box and could look. I took off all my stock suspension.
AllMoparParts.com
AllMoparParts.com
- Benny
Preferred Vendor
All
All
L/R Spindles.
L/R Tie-Rod Ends
Shane
Hi Shane,
All parts from a 2014 follow all the way through to a 2019. If you would like send me your VIN and I will message you schematics of your truck and also a Rebel to compare.
-Benny
azcoyote
Phoenix
-Benny
I am sure the costs change but you should throw up the approximate total. Just as a curiosity.
Moises Flores
phoenix
Front Bumper Parts
-Benny
Hello Benny, I have a 2017 Big Horn and want to do Rebel front conversion.. are all these parts listed necessary for the conversion
or can i just simply order the Grille, Bumper, Letters, & Center Cover and bolt to existing brackets etc? 2017Ram.jpg
