ram using oil
jesie123
Hi. I have a 1998 ram 5.9l that is using a lot of oil. It doesn't smoke and doesn't appear to be leaking. I pulled the air intake and looked in the intake but there was only a couple of drops of oil in it. It was actually really clean inside. Any suggestions on what else to check?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
My automatic suggestions are a leaky plenum or valve seals. The plenum can leak and suck oil without even showing it in the intake, so that's a major possibility.
pubsafetyram
Check your PCV. They will definitely cause oil usage. Be sure to buy the Mopar valve and not an off brand; it DOES make a difference. I have personal experience of my 290,000 mile 5.9 using a quart every 400 miles until I got rid of the new oreillys valve and replaced it with a Mopar. Now it doesn't use hardly any oil.
joshhhh
