Ram vs Durango bolt pattern
brianw0048
EcoDiesel
Qre the bolt patterns on a 2016 Ram 1500 and a 2017 Durango r/t the same? Would the wheels be interchangeable?
Thanks.
Sent from my HTC6545LVW using Tapatalk
JB1
Houston, Texas
Durango is 5x127, same as Jeep
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
Even if they had the same bolt pattern, I believe the offset will be the determining factor.
I believe Durango OEM offset is in the +30 to +38 (or so) range and that might be dependent on whether it's an AWD or RWD model. The Ram 1500 has a +18 offset.
MADDOG
Living in a Firepit
A 2017 Durango wheel is a 5 x 127 bolt pattern with an offset of +55 - +56 mm depending on which engine and wheel diameter.
A 2016 Ram wheel is a 5 x 139.7 bolt bolt pattern with an offset of +10 to +25.4 mm depending on which engine and wheel diameter.
They won't interchange.
