Rambox divider templates?
BubbaGump
Does anyone know where I can find printable templates for the rambox dividers? I've searched and searched and can't seem to find any.
Or would anyone that has the mopar dividers be willing to trace them and email them to me?
I've read that the mopar horizontal floor panels are too thin, and bow under pressure, so I want to build my own with thicker material. Thinking either 1/4" abs or MDF board. I've also got plans to integrate a single rifle holster using some ATV clips and cut out a portion of the verticals. So I can utilize the dividers still.
Please let me know!
My email address is:
[email protected]
Thank you!
Banessi
Sarasota, FL
5.7 Hemi eTorque
It would be helpful to post where this question was already asked. I had the same question and this post was in the search results first.
[email protected]
Cape Coral FL
I'm also looking for templates also for my '17 Laramie's Ram box dividers. Any help is appreciated. I believe 1/4 inch will be the desired thickness. Trying to make it out of 3/8 inch for now since I can't find anything to go by & I have scrap plywood to work with. The width between vertical guides should be 9 1/4 inches. Height is to your preference. I made my test template 6 1/4 inches just to see if I wanted to go higher or not. If you want to go higher, the top of the vertical slots on the outer side curves slightly out. Still working on the horizontal pieces for the front & rear. More pics later.
[email protected]
Cape Coral FL
I did finish making the templates for my 2017 Rambox if anyone needs them. They might work on other model years but I don't know since I only have my year to go by. Far cheape than buying Mopar OEM, which are $75+ on Amazon.
Brent L
NC
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Painted plywood works too if you don't find the printed version.
Tumbleweed
Make a CAD?/CAM* Template. Seems like it'd be pretty simple.
*Cardboard Aided Design/Cardboard Aided Manufacture ;-)
Brandon-w
Yukon
2015 Ram 1500
Don't run with scissors or smell The markers, if you do you'll be prime minister of Canada in no time.[emoji23][emoji50]
jejb
NW Arkansas
I bought some plastic cutting boards from Wally World and cut them to size.
