Rancho QuickLift Leveling and body lift?
sulrd
Hello all - I installed a Rancho QuickLIFT Loaded Leveling Struts (front) and RS9000XL Shocks & Struts (rear) to level out and lift my 2015 RAM (2' and 1.5").
I'm very happy with the leveling that was provided but want to go bigger with tires and wheels and was thinking about an additional 2-3" body lift. What are your suggestions? Will I need to change out anything or simply do the body lift?
Thanks in advance.
dan1911
Fairbanks, Alaska
I think with what you currently have you can fit 35s in there.
I have Bilsteins set at 2.1 inches in front and have 34x11.50s with room to spare.
Im sure someone will be along shortly to give you more options, but I know 35x12.50 should work as long as you have the correct offset to avoid rubbing
jarzo
Austin, Texas
I have the bilsteins set at 2.1 with a 1.5" body lift. My advice, go with the 3" body lift...I wish I did and may end up switching for the 3".
You'll be surprised how much work is involved with the body lift but worth it.
DILLIGAF
Canadian Forces
Canada
Here is my setup, same as yours but with Zone body lift, Lots of fun putting it on :)
