XXSNOTRODXX
Did you ever get your problem sorted out? I have a 2013 and have had an intermittent long cranking issue for quite some time. Seems to be more of an issue with cooler temperatures.
Sorry it took so long to respond. I was on vacation.
No I have yet to figure out what causes it. I can say that it is not related to spark plugs though as I just put 16 new plugs in it yesterday as per the 60,000 mile maintenance schedule and the 2nd start of my truck after having did the install was a "extended crank start".
It has never NOT started for me...but the random extended crank start is enough to worry you on WHEN the day may come that it decides not to start. AND it can be slightly embarrassing. For example, I was at my brother in laws a couple months ago and was picking on his Chevy and how superior my Ram was....get in my truck to leave his drive way and "CRANK CRANK CRANK CRANK CRANK"....I didn't hear the end of that one haha.
I have yet to try a new battery ( I doubt that it is related to the problem because it has plenty of cranking juice....BUT it is the original battery).
Not sure if it could be related to something to do with the tip start/hill start features of the truck,random hiccup with the cam or crank position sensors or what.
Probably 90% of the time it fires up without hesitation and runs great. But other times you turn the key and let go of the key and the tip start feature takes over and continues to crank until the engine starts which can sometimes take around 5 seconds worth of cranking. And normally when that happens it almost "stumbles into running" rather than a "VROOM" when it fires up. (hope you follow what I mean lol).
If you find anything let me know please!
