WiSH2oo0
- May 15, 2016
- 378
- 144
- Location
- MN
- 2017 1500 Express 4wd RCSB
- Hemi 5.7
Good morning All,
New member and first time truck owner
So I bought my first truck and it came with a 4" RCX lift kit. I noticed when getting in and out of the vehicle there was a squeak coming from the rear of the truck. After some investigating I found that it was the rubber bushing on the driver side rear shock that connects to the frame.
After I had compressed the shock it would not extend and just stays in the compressed position. So I'm looking for two new rear shocks now. I took a couple of measurements while I had the shock off the truck. The rear shock also has a rubber bushing on the piston rod. So I'm not sure what measurements to use. I measured from center to center on the mounting bushings.
Compressed length with rubber stop bushing on the piston rod - 18.5"
Compressed length if the rubber stop bushing was removed - 17"
Extended length - 29"
So I was looking for either some new Bilstein, Fox or Rancho replacement part numbers that would work.
Thanks
Thanks
