Re-Gearing for Lift
I couldn't seem to find any info about this, hence the post.
I have a 2019 Laramie 1500 4x4 crew cab. I want to lift but want to re-gear for the lift. As I understand there is nothing for the front diff as of now. However I understand you can replace it with an older diff from a 4th gen. my questions?
Is this basically a direct bolt in?
Do components on it need to be changed such as driveshaft yolk or bushing?
Are there some upgrades to look for when looking at diffs? Examples: Buying a diff with a 3.92 gear set wont require the purchase of a new carrier, for a larger gear set. Look for one with a factory locker identified by (such and such).
Is there a gear chart for the ram for ideal gear for tire size?
Thanks for any help.
RAM-pagingMN
Alexandria, MN
You dont have to re-gear for a lift, but for Wheels and tires it would help. Ive lifted all my trucks and never re-geared, no issues to think of. the 8 speed really helps with larger wheels and tires.
Anthony Bulger
I want to add larger tires when I lift hence the need to re-gear. I don't want to loose performance.
RAM-pagingMN
Alexandria, MN
fair enough. I didnt see that much of a loss with 37x22x13.5 lost maybe .5 second on 0-60 runs. adding a cat back exhaust, pedal commander helped bring it back though.
RAM-pagingMN
Alexandria, MN
I had the 4.10s on that truck, but I had a 2015 with 36s and 3.73 again no issues but did have cat back and CAI which offer minimal gains without a tune.
ameer73
