Rear Air bags for towing. What are you using????
PW636
Clarence NY
Just seeing what most are using for towing. Just looking to ad some additional support for towing. I have a 1 1/2 Rear leveling kit but want to ad air bags.
Any ideas.
Thanks.
Administrator
Rear level kit? Does that lift or lower the rear end from stock height? Usually someone lifts the front suspension to level the truck.
If it lifts the rear, you can probably run any of usually rear helper airbags available. There is the Airlift 5000 and Timber Grove frame to axle airbags, both offer spacers for 2", 4" and 6" lifted trucks which you may not need. Both are no cut installation. The Airlift 1000 go inside the rear coil springs, their downfall is they need to be fully inflated before loading the truck.
OC455
Central NY
Timber Grove ASAM
P
PW636
Clarence NY
Thanks for the input.
After emailing Timber Grove they seem to know what I need to get the job done on my PowerWagon with the 1.5 rear lift spacers.
Thanks again.
P
PW636
Clarence NY
Thanks for the help an input!!
Tim at Timber Grove was the great. He knew what I needed to get the job done right. 2016 PowerWagon with a 1.5 lift spacer.
Kit came with everything I needed. After a quick review of his install video I was able to install his airbag kit in 45 minutes from start to finish. Great quality product and his knowledge of what I needed was far above the rest.
I highly recommend. Timbergrove Airbags.
olyelr
Kewadin MI
Do they limit suspension travel (extension and/or compression) at all?
wakemeup
Ventura
timbergroveenterprises.com.
Did you inquire or think about Daystar cradles? Curious what Timbergrove thinks of them. My installer talked me out of using them. He said I wouldn’t need them for a stock lift. That was his opinion though.
reyzapien88
