Rear Coil Spacer Help
Jericho
St Albans Vermont
3.6l V6
Hey all first time poster, long time lurker. Looking for some help and opinions. Recently went from a 2" leveling spacer to a 2" leveling strut on my 2017 Ram. Been about a week and the front end is still riding higher than the rear. I've decided I'm going to give it a solid month especially with the cold weather here in the north country and take it down some back roads and give em a work out. But I have a feeling I'm going to need to lift the back a bit. Been looking into these coil spacers but can't seem to find anything about them, good bad or otherwise. Hoping you fine folks will be able to help. Thanks!
https://motofablifts.com/c-1390577-dodge-leveling-kits-rear-kits.html
Big_Kahuna702
Las Vegas
Regarding rear coil spacers, if I plan to raise the rear by an inch, do I go with a 3/4" or 1" spacer. Not sure if spacers are true to height.
kurek
Northwest
In the rear the spacers are true height since the coil spring is located directly over the axle there is no ratio or leverage. A spacer which measures 1" thick will result in a 1" net lift.
