Rear coil spacers with stock shocks?
BWatson22
Midlothian, VA
2019 Ram 1500 Classic Warlock
First post on here....
2019 Ram 1500 classic, warlock, 4x4
So a 4th gen ram.
Would 1.5" or 2" rear spacers be okay with the original factory shocks. I don't want to over extend the shocks too much or cause clunking/ noise. It's hard to find lift shocks for the rear to fit.
(Bilstein 5100 2.8" in the front, and I want rake. I think the 1" bilstein rear shocks would be kind of pointless but I'm not sure)
crazykid1994
Rear shocks. Not struts. Front are struts. I tagged you in a warlock thread that should answer your question
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
So a 4th gen ram.
No
atreides
USA
I had 3'' spacers with factory shocks for a short while. It sucked and the shocks are now even more blown than they were before. Get lift springs and proper extended shocks.
zogg
Southern Illinois
2018 Ram Express Quad Cab
I replaced my rear springs with 2” drop springs, which i know is not what you want. But the point is that when i removed the springs, the spring pockets were not very deep… l would estimate less than two inches. Hence, with spacers added to either end of the spring, i dont know if any of the spring would be inside the spring pocket….hence it could fall out??????
Seems like 2” lift springs would be a better choice and use extended shocks. Then everything would be correct.
MoparFin
U. S. Navy Vet - AS1
PA
I have 2" lift spacers in the rear of my 18. Stock shocks. Rides fine, but I do get a little bump steer in the rear over large bumps on the highway. I will add a track bar bracket at some point.
Only time it sees dirt is dirt roads in state game lands and campgrounds.
metalchewy
Las Vegas
2010 TRX4
4.7L
Sounds scary AF in the winter. Bump steer on the rear on an icy overpass is nothing I would ever accept as OK.
MoparFin
PA
When the roads are icy/slippery I'm not driving fast enough that I get it. Have to be doing 60+ and hit a big bump.
Its honestly very rare that it happens, but it does happen.
Justin33
Is this what I get when I go over expansion joints on an interstate bridge?
MoparFin
PA
Probably. Does the rear seem to kick to one side when you hit large bumps?
danielmid
Southeast WI
2015 Sport 4x4
Mine was wicked with Icon springs and longer Fox 2.0 shocks. I had to install an aftermarket track bar to calm it down, then upgraded rear lower control arms helped even more.
Justin33
Mine feels like it’s jumping one way or the other. I just chalked it up to an empty bed but I guess not.
MoparFin
PA
Remembered this thread and thought I would post. I just replaced my factory rear shocks with Bils 5100s for lifts. I have 2" spacers on the factory coils. I am no longer getting the jumping you explained when I hit large bumps going highway speeds. It rides WAY better. I wish I would have replaced the shocks sooner.
Justin33
I have bilsteins front and rear so it can’t be that I wouldn’t think.
MoparFin
PA
Do you have the rear lifted and do you have stock length Bilsteins or Bilsteins for the lift you running?
Justin33
Rear is lifted with a longer spring and I’m pretty sure the bilsteins are made for the lift I got the super lift off nick here who is a vendor.
Christopher60
