Rear-end Issues Again.....
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
So pinion bearing started howling again and it seems to be the bearing is likely failing. So far since I bought the truck with 27k I have put 3 pinion seals, u joints, and this will be the 3rd set of pinion bearings. I am beginning to wonder if the driveshaft is an issue since I have had issues with vibration and multiple installers have installed pinion bearings that have failed and seals that have failed. I have tried 3 brands of pinion bearings too, koyo, timken and some other napa brand.
Any thoughts chime in please.
09SMOKINHEMI
TEXAS
ouch.... not good news bud. sorry to hear you're having troubles
jlb
MT
CTD
Your 4.56 install was a mass produced product right? Since you have the pre-2011(?) axles, but is it possible they screwed up the install, and the ring gear wobbles or something?
KLRpanda
what degree is your drive shaft at?
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
If the driveshaft was the problem, it should be affecting your transmisson as well, unless maybe the pinion end ujoint yoke is machined off center in relation to the d/s.
I'm wondering if they left something out the 1st time they did it, and no one has put it back in. Some axles have things called flinger rings that help get oil to the bearings/seal, and they look just like a spacer or big washer. Without them, they could be starving for oil.
smiley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Well I emailed Chrysler and got a response from a case manager who is going to call me and see what can be done. I pointed out I have had everything in there replaced and just want to find solution not complain.
$miley
smiley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Dropping off the truck tomorrow they will have all week to get it fixed and hopefully find what went wrong. I have aftermarket warranty that I am trying to get to cover the repair... we will see when I get back on Friday if it is done and correct or not.
Etroze86
Grand Forks ND
Hey Smiley Im from the Fargo area. Which dealer are you going to?
smiley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Had been going to Corwin had nothing but problems in fact they created the problem when they first did the pinion seal. I took it to my friend at Schumacher Downtown to get it done correctly.
$miley
Etroze86
Grand Forks ND
Yeah good idea smaller garages that see everything usually can find a problem and fix it right the first time. I'm not a fan of any of the dealers in the area just because most of the tech that work for them don't have time to actually trouble shot the problem they just throw parts at it hoping it will work because thats what the dealer wants them to do.
Red94yj
Sad to say but dealers usually just do routine work. In my opinion I would have taken the truck to an offroad shop. They do gear installs, axle swaps, and driveshaft work everyday. Well trusted business for this type of work. They would have fixed it the first time.
Take your driveshaft off and have it balanced again. If its off a hair it can cause terrible vibration.
Good luck!
smiley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I don't think we even have an off road shop. Dealers are indeed good at trial and error parts swap. They struggle with actually problems or anything none traditional.
$miley
smiley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Well good news it was not the pinion bearing this time. It was the outside carrier bearing. My friend said it was weird because the bearing had started to come apart. The best news is that the warranty company is covering under warranty and I am only paying $25 which is my deductible. The Yukon kit we used during Auburn install had Timken bearings which I thought were good so must have just been a bad batch or something. Pick her up tomorrow and will have her for the move. Time to do some towing.
$miley
smiley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Okay so apparently I am contradicting myself. It says on the work order that they replaced inner and outer pinion bearings, crush sleeve, and lube. It was 522 in labor so glad I was not buying.
$miley
smiley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Good timing too we had some snow and ice stuff here so glad to have it back.
homeyclaus
just shopping
perhaps
We used to have a lot of issues with rear differentials if pinion and ring weren't spaced just right. Bearings and seals would then fail all the time. GM, Dana, Toyota, all need attention to detail from the mechanic putting it together.
As you discovered, finding the guy (or gal) with the right amount of attention to detail is a crap shoot most of the time.
WhiteExpress
Midland, TX
I'm sorry for your run of luck here! I attempted an install on my '00 9.25. I'm not sure what I f*d up, but I did something wrong. Just paid my trusted mechanic to do it again, never had an issue after that.
joshhhh
