Rear led tail lights w/ black housings
TXKID
Houston, TX
So this morning on my way to school, some ******* cop with nothing better to do decided to pull me over for my lightly tinted tail lights in which you can still clearly see red without even pressing the brakes and with the reverse lights still uncovered by any tint. So now I have to "fix" them, even though there is nothing to fix, or pay a ticket.
My question is where can I find oem quality led tail lights with black housings that are "legal"? I have looked at recon but if I can pay less for some of the same quality it'd be nice.
UNBROKEN
2012 Ram R/T
Get a list of cars that come stock with tinted tails with some pics of those and yours and go fight the ticket.
Cars as early as 1988 Thunderbirds had tinted tails. Chevy Trailblazers also came with them stock.
That's all if yours are truly "lightly" tinted. If they look black like most of them you'll lose.
TXKID
TXKID
Houston, TX
They really aren't fully black
You think this would hold up?
Musclemckeester
Houston, TX
n/a
n/a
BigSexyBlue05
2012 dodge ram quad express
ljvsnyder
s. Illinois
Add some red led tail/brake/turn signal ligjts to your rear bumper. If the texas law is similar to the Illinois law which reads as follows:
Every motor vehicle, trailer, or semi-trailer shall also exhibit at least 2 lighted lamps, commonly known as tail lamps, which shall be mounted on the left rear and right rear of the vehicle so as to throw a red light visible for at least 500 feet in the reverse direction,
Just read the texas law. Adding red leds to your bumper would do the job. As they only need to be visible from 300'. You could take video of your ligjts from 300' to be in compliance on the ligjt output. The other issue is a red reflectore visible from 500' away. Simple as two pieces of reflective tape or reflectors attached to your bumper on each side.
spankis
Cummins 6.7
A lot of times they will get on you having a red reflector, too. That's how many DOT taillights are registered. Even the tinted ones, if they are DOT approved, have an untinted reflector of some kind. I believe that is also a requirement of many state transportation laws too.
ATOM
ever consider the oem ones that come on the new'13 sports? spendy but they are oem, can't give you a ticket and they are slightly tinted
Cynix
Edmonton
2013 Ram 1500 Sport
Also if those are nightshaded you can use gasoline to take the nightshade off easily unless they are clear coated then it's a bit harder
TXKID
TXKID
Houston, TX
Yea I took em to a place to have em done and I think they're clear coated, but I was looking at the spyder led tails with black housings, has anyone seen those in person?
If not ill probably go with the ones Kevin posted bc those are pretty sweet
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Are your stock tails tinted? I haven't had a problem so far with the CS cops and I've had plenty driving right behind me down university and Texas. But they're also LEDs tinted.
JCJ4290
2014 CC 4X4
The only place that I found that advertises being street legal are the Recons. Though I don't know how seeing as to how they really aren't that bright, but they give you a form with them
TXKID
TXKID
Houston, TX
Yea they're the stock ones, and I was over in Bryan and some cop on a motorcycle with nothing better to do pulled me over
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
The ones kevin posted are my favorites.....
I have had 2 sets on my truck. Matt (lb3711) has the first set now (tinted) and I have a chrome/clear set that we did in mineral gray.
Have I been pulled over? Yes. 1 time. Cop said he couldn't see my reflector, and that they were too dark. Ummmm......wrong. I had a set of tails with me (stock), swapped them in and showed him that mine were brighter than stock. And.....as for the reflector, no you aren't going to see that from 30ft away at 3PM in July on a sunny day. *********.......
Bottom line, I love 'em - and the tinted ones are HOT.
WVUguy
Loveland,CO
2012 EXPRESS
i just got the spyder smoked tails and i have to say its not as dark as they look...actually their not dark at all...might consider it?
imazman
2013 Ram
I'm not sure I understand the logic of requiring the need to see red plastic. Seems like as long as it lights up red when illuminated and meets necessary lumens then it should suffice. With that said, they should allow tinted tail lights but simply require a higher lumen bulb to replace the old bulb...likewise for headlights too.
/Z/
BoatRam
I would do something like this
timthumb.php
Ram725
Jackson TN/Houston Tx
2012 Ram 2500 Crew 4x4
6.7 Cummins HO
I have the Ebay specials Jake09 runs. Couldnt be happier with the look and quality.
Ram725
6.7 Cummins HO
CaliDodgeRam
California
Add a tailgate bar and swap with someone who has stockers for a day to get the ticket signed off, with a tailgate bar you should have no problems down the road when you put yours back on.
Arturo Rojas
