Rear Locker
fnfal
I need some help...
I have a 2008 2500 Hemi 4x4. Love my truck but what a POS in the snow! Hate to admit it but my Chevy would have eaten this dude alive off roading! I want to install a rear locker but honestly have no idea what rearend my Dodge has....
Any help/guidance would be appreciated.
BrianandChrissy
Buffalo NY
2016 big horn crew cab
5.7 hemi, vararam CAI
Crickets......
Sent from my LGMP450 using Tapatalk
Cardhu
MB CAN
I will have the check. Not exactly sure how to confirm what axle I have. A search of the web doesnt help much....
use the diff wizard on that site and count bolts on your differential cover.
yillbs
Or post your VIN and we can look it up :)
fnfal
fnfal
Well I have 14 bolts so according to the DiffWizard I have Chrysler 11.5. But, my bolt pattern doesnt look at all like what the 11.5 is???
I can send someone a pic. I cant attach the pic here.
My diff is squared off on the bottom, instead of one bolt at the very bottom, I have 2 side by side . And is stamped AAM
fnfal
fnfal
Found a match...AAM 10.5
different than the chrysler 10.5
fnfal
fnfal
One more little surprise....I have 2 wires going into the top of my diff case.... Electric Locker?
So, I contacted the good folks at Dodge and just got my trucks "Build Sheet". It confirms my axles,the rear is AMM 10.5 and the front is Chrysler 9.25
The build sheet says my truck has "Anti-Spin" rear end. From what i can find on line that is a Limited Slip option. But that does not explain the two wires that enter into the top of my differential. I removed to cover (oil change) and you can barely see the connector in the back behind the pinion etc. but cant make out any thing else.
The saga continues.........
joshhhh
