Rear seat lifting for subwoofer box.
rotwiler
rotwiler
Washington
Just got my new bolts. Stock is M12 1.75 thread 50mm long grade 10.9. I bought M12 1.75 thread 75mm 12.9, which are approx. 1" longer and a higher grade.also got plated so they are less likely to corrode
Thank you very much!
rotwiler
rotwiler
Washington
I ordered 90mm black 10.9 like stock, I already put 1 inch spacer in and seat still touches top of sub surround barely so thought a little extra would be better, box I have is tall. Also even after lifting 1 inch seat still won't fold forward. Soon as these bolts come in will finally have some good bass. I did notice after I removed fold flat floor and lifted seat, the stock alpine that I modded some, sounded better.
BWL
Embrace the skeptisism
BC Canada
There's 3 different thread pitches for M12 so hopefully you ordered the 1.75
88ROOK
illinois
You guys know the federal regulated torque specs on those bolts?
BWL
BC Canada
I think it's right around 35ft/lbs, but not sure
BWL
BC Canada
Ft/lbs or NM. Most seatbelt bolts are in the 35 ft/Lb or 45NM range. I figured since the seatbelt anchors were on the seat bolts it would be similar.
88ROOK
illinois
Seatbelts are a minimum of 40 ft lbs, i use to have to repair them
BWL
BC Canada
Good to know. I snapped a head off one of my seat bolts putting it back in last time so maybe using a torque wrench this time is a good idea.
Chief_6.7
I was afraid of something like this if I would have gone with a box made by one of my buddies who does custom boxes. I decided to go with a fox box to avoid all this hassle. My seats fold down no issues. All I need to do now is get longer bolts and I would also like to swap out the MDF spacers for some aluminum or steel ones. It will just help me sleep better at night knowing I have aluminum or steel as a spacer. Here’s what I have below and it sounds amazing
bigred74
Illinois
1999 and 2017
5.9L Magnum and 5.7L hemi
Where did you buy and how much?
Local dealer told me seats are 35ft lbs
Reactions: BWL
BWL
BC Canada
IMG_20180501_125753.jpg I bought them at Fastenal since I had to go there anyways. They didn't have the 10.9 in stock so I went 12.9 in the hex head type. Bag of 10 was 11.90 CDN + tax. They don't have the tapered threads like the oe ones so they're a bit harder to start.
BWL
BC Canada
Progress on my seat lift. Load floor is now use able and doesn't vibrate. 3/4" seat lift and 1/4" load floor lift. Still waiting on aluminum, but after mocking up the 1 side I'm satisfied with the resultsIMG_20180503_153857.jpgIMG_20180503_153625.jpg
rotwiler
rotwiler
Washington
Box is in now, could have went with a little shorter bolt like 75mm since I had to put 3 washer to keep it from bottoming out. Seat folds, but there is no reasonable space to be used on the quad cab. Just need to mount amp and rest is done.
88ROOK
illinois
There is no way those bad boys were in there with 35ftlbs.
have to be, they are done with a federal regulated electric torque gun that is monitored by a computer, if it doesnt reach the minimum torque spec, the computer will fault out and shut the production line down
sublime2300
