Rear Windows Stopped Working
JOHRY
Ontario, Canada
EcoDiesel 3.0
So last night I go to try and roll down my rear windows, and NOTHING. Thought maybe it was drivers door switches (even though both drivers and passengers windows wouldn't work). Tried window switch at each rear door, same thing, no response. Lock button (drivers door and both read doors) works fine.
I looked and don't see a fuse specific to Rear Windows. Any other thoughts?
turkeybird56
Central Texas
Have read several posts other areas where ppl say all windows stuff powered through TPM. I do not know, sorry, no way to help U on this. Somebody who is a wrench turner a lot better than me may chime in and help U. Another person said check wires under drivers seat, make sure all connections connected (not know about that)..Supposed to be (1) silver module master fuse for all windows, but not sure, hard to find info specific...
U might have to go to dealer to have checked..Just saying...
Check this URL:
Sparky853
2017 1500 SXT CC 4x4 6'4" Air Suspension
I had a similar problem, only it was just with the drivers side rear window. When you try to operate window, do you hear a relay clicking on the switch? That's what mine did, got a replacement switch module, all better. I was also able to switch module from passanger door to driver door to test.
Sent from my VKY-L09 using Tapatalk
Steve58
