Rebel Wheel specs?
hodge-xj
5.9 cummins
So I've been searching and can't quite pin down what the exact specs are for stock rebel wheels. I'm hopefully picking up a set Friday after work, and have a set of 315 duratracs I'm gonna toss on an. I've searched enough that I'm aggravated so I'm hoping someone has some info I may have missed or misinterpreted.
As per the sticky in the tire and wheels section it's showing them as 17x8 with +25 offset, than I came a across a few threads saying they are 17x8 +18. Just trying to make sure I don't rub the upper control arms. Seen a few pics of guys running them without problems, but the threads were short, old and had minimal pics. My 285s on stock 17" aluminum wheels clear the uca but not by a ton. These duratracs aren't overly agressive and have the same section width as bfgs which guys clear with no issues.
Attached is the info I've found.
stock rebel wheel:
size: 17" x 8"
offset: +18.05mm
bolt pattern: 5x5.5" / 5x139.7mm
weight: 29 lbs.377b84e4b2a4d640a5bc5da6db1bedc6.jpg
Sent from my SM-N920V using Tapatalk
TXCOMT
Good stuff!
And just in case somebody in the Dallas-Fort Worth area needs Rebel wheels, I've got a set listed in the "For Sale" forum here.
TXCOMT
H
hodge-xj
5.9 cummins
Good stuff!
TXCOMT
Wheel data confuses me. I get backspacing, but offset and width gets me all bassackwards. Still not sure on rebel wheel specs.
Hopefully I don't need to get spacers to clear the uca. Haven't found many pics to confirm or deny it solidly
TXCOMT
Yep, after reading your original post, I'd be willing to bet there could some fitment issues with that wide a tire, but I could be wrong. I hope I am, for your sake! Good luck and keep us posted.
TXCOMT
H
hodge-xj
5.9 cummins
Had to cancel these plans. Washer decided to die on me.
Sent from my P00I using Tapatalk
stateofdade
Trenton, GA
Cummins 6.7
I've had plans for a muffler, bed mat, bull bar, and light strip under the tailgate for 3 months as well. Always something.
Sent from my SM-G935U using Tapatalk
