Recommendations for Tonneau Cover - My requirements...
timotheus
Cullman, Alabama
5.7L Hemi eTorque
Hello everyone, I did a quick search and didn't see a specific recommendation meeting my requirements. Therefore, figured I would take a quick poll. Just purchased a 2022 Ram 1500 Limited with 5.7 foot bed. I need it to be secured or locked. I'm thinking of getting the Mopar tri fold cover, but not sure. Any suggestions? Also, I just purchased the vehicle. I'm thinking Ram or Mopar may send some coupons. Appreciate any feedback or advice. Thanks!
Nick@GotExhaust
Supporting Vendor
SC
We offer most brands. Check out the BAK MX4, that is the most popular cover that will check all the boxes for you. We can offer it at a great price
Message me if you would like a quote on this or any other bed cover.
DILLIGAF
Canadian Forces
Canada
Mopar Tri-Fold is junk, delaminated after just 2 winters.
My Bacflip is on its 6th winter and starting to show its age. But at least its never gotten water logged... lol...
turkeybird56
Central Texas
I have a full tonneau cover, mopar and paint matched. But stupid expensive. Not sure on just how secure, maybe a roll n lock or one of the Diamonds ones may secure more, but what I have locks also.
Docwagon1776
Midwest
I've had the TonnoPro soft tri fold on my old truck for 10 years. It started losing stitching somewhere around year 7 and TonnoPro replaced it for free under the lifetime warranty. That truck is now my son's truck and the cover is still on it. The cover has been extremely weather proof and I've not had anything in the bed get wet using it. No dealing with drain tubes, since it sits up a bit over the bed and doesn't hold water.
I just bought the exact same for my PW. It doesn't "lock", but it does clamp down and you can't undo the clamps without dropping the tailgate, which does lock. Someone with a knife could get in, but nobody is cutting covers just to see what's in the bed.
I bought the first one from Summit Racing, and the second one from Real Truck here on the forum. If you PM them they'll send you a price that's under what I found anyone else selling it for.
gofishn
Iowa
hemi 5.7L, 345 cu in
Got a Truxedo Sentry CT cover and like it, metal slats, wrapped in Nylon type and velcro rails on side with a pull string to realse which is hidden when tailgate up, No cutting the thing and pretty secure.
Dredger
SE Ohio
RetraxOne MX Retractable Tonneau Cover. Note: You will lose a bit of bed space because the cover rolls into a canister located at the front of the bed. Otherwise, an excellent product!
Mb7640
Fountian hills az
I have a peragon works great. Cam be locked no leaks and can be removed easily if you need to use the entire bed. Was going to get a back-lit I did not like that it covers the back window if you need to use the bed.
jejb
NW Arkansas
I also have the Sentry on my 22. Had it on my 18 also. I like that you can't just cut it to get into the bed, and that it is super easy to remove if you need the entire bed. I looked hard at the bakflip, but as gofishin says, it blocks your entire rear window when fully opened up. I like to keep a better eye on what I'm hauling then it allows. Yeah, you can switch on the cargo camera, but it only stays on a few seconds at a time.
gofishn
Iowa
I looked at the Peragon but thought it stood slightly higher than the Truxedo Sentry CT. I wanted to keep the body lines, as much as possible, if I was NOT going to get a Topper. That PEragon is a very nice cover. Doubt I;d have regretted buying it, if I had not gone with the Truxedo
KeithP
Hemi 5.7 VVT
Undercover tonneaus are very secure. I’m on my 4th one. Zero complaints.
Cabinetman
Thomasville, Ga
5.7 etorque
I'll go with the truxedo like I have on my F150. I like how it rolls up easily to use the bed and you dont lose any space. As far as security, I never keep anything that valuable in my truck bed.
ColesRAM
NE FL
5.7 V8
I have a 2020 Laramie 1500, short bed. Got a Gator four-fold (Bikflip) off Amazon. Easy installation, locks up nicely and appears durable. Been outside since July, thru two hurricanes and recent freeze. So far, all good.
JJEH
Central Texas
get a Bakflip. You wont be sorry
Well, depends. We've got the G2 since 2018 on ours and the Oklahoma hail was beating it up pretty good, so the aluminum layer is bending upwards. And it's not waterproof. While it has built-in drainage and tubes to reroute the water out from the bed, it is NOT waterproof. So don't put anything important back there. Their other models might be a better choice.
T
timotheus
Cullman, Alabama
5.7L Hemi eTorque
Hello Nick, I messaged you for a quote. Thanks!
wiggy999
Ottawa, On. Canada
Very impressed with BakFlip service. I bought a USED G2 hard tri-fold, and they quickly sent me hardware that was missing, no questions asked. FREE :)
jejb
NW Arkansas
Great to hear.
Sentry is really good that way too. When I swapped the Sentry cover from my 18 to my 22, I needed all the seals. They would not take any money for them, and they arrived in 2 days.
Fatboy1989
