Recreating wiring harness
HelpIAmAParrot
360ci
Hey all, new member here. I have a 1988 D350 ex-Forestry Service truck with the 360 and 4-speed in it, service bed and 2000-lb. Autocrane on the back. My plan is for it to be my race hauler/support rig. I'm thinking of replacing the Thermoquad for a ****** EFI at some point for reliability and just general ease of use. But right now, I'm in the process of rewiring the whole truck as it is now- half the accessories don't work, and the other half are so chooched together with different bits of wire that it's a miracle anything works at all. So I've taken the wiring harness entirely out of the cab- engine bay, cab interior, dash, gauges, roof cargo lights, the whole shebang.
My initial thought was that I would completely remake the entire harness from entirely new wire, all new bulbs, use a label-maker loaded with heat shrink, braided wire loom, conduit, you know, really do it right and essentially build the new one side-by-side to the old one. I would try saving what connectors I could with a parts cleaner and replacing what wasn't salvageable, either because the plastic connector was broken or the metal spade connectors inside were corroded. But some of the unsalvageable connectors are pretty goofy looking, seemingly mostly connected to relays- there's one with I think 7 connectors on it mounted at 4 different angles that I know is not going to be on the AutoZone shelf any time soon. I also have one of those connector de-pinner sets from Amazon and the metal spade connectors inside these things also seem to be proprietary, or at least I couldn't find replacements in bulk.
So, is the only solution really to scrounge eBay and pay some of the ridiculous prices on there for these 1-off connectors? Is there a place to buy just the metal inserts that click into the connectors? Should I look at wiring up some Bosch-style replacements of any relay configurations and just using that form factor where I can?
S
Slinge
Guest
Maybe look at Haywire & Company....and there are others
armyvet25
Lorain, Ohio
Dodge 1969 383ci
Depends on your tech-no skills in wiring and how much you want to spend, personally, if I was doing it, I would start with an FSM so I would know exactly how everything was wired in the first place and use it a a general guide. then maybe buy a generic preformed generic wiring harness off Amazon, and proceed to rewire per manual with a lot of improvements along the way, reuse the original fuse box along with a supplementary one for additional accessories/radio/amps/extra lights etc etc.
But that's me a I can rewire a completely bone empty carcass.
armyvet25
Lorain, Ohio
Dodge 1969 383ci
get this factory manual, I bought one and it was worth it's weight in gold as I've had to rewire most everything from dash to engine compartment to lights etc.
plenty on ebay...original and CD and reprints
