Regarding Headlights
Eightd21
MI
NA
NA
I'll preface this by staying that I'm not (yet) all that mechanically inclined. With that said, just how bad is it to access the bulbs on an '18 with the projector housings?
The owners manual makes it sound relatively simple, but I've seen tons of people online commenting on how they're breaking the clips and such.
I really would like to improve the lighting on my truck, but at the same time I don't want to start breaking things on it haha.
17Veteran76
Georgia
On the 17's you have to remove a plastic clip on a cover behind the light inside the wheel well. The clip is easy to snap, but easily replaced.
There is a clip inside, you push in place.
Then a 2 bolts on the top and bottom grill side on each lamp. Plus a couple of grommets.
Pull head light out. Standard twist connectors.
10mm.
Its not hard. Take ya 7 or 8 minutes for both.
If you are trying to go L.E.D you will need the conversion kit if you have halogens.
tidefan1967
Summerville, South Carolina
Just be careful when/if you pull the grille and headlights out that you don't scratch the hell out of your paint. I've had mine out on two different Rams several times and I always use painters tape and rags to cover it after getting some scratches the first time around. The 4300K and 5000K HID kits Diode Dynamics and Xenon Depot both work well and have good warranties(although neither are particularly inexpensive). I also tried a cheaper kit from Amazon on my old 2001 Silverado and had nothing but problems. Don't forget your anti-flicker /Canbus modules to avoid the dreaded bulb out message.
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
I have done this multiple times, on my 1500 and 2500. As said it isn’t as much of a pain as you’d think. I haven’t broken any clips yet. It is easier on the 2500 with the extra space in the wheel wells. Good tip about watching the paint on your bumper.
Eightd21
Eightd21
MI
NA
NA
Thanks for the replies and info, I guess the only way to do it is to just do it haha. That tip about protecting the paint is great too.
Now I just need to decide if the Opt-7 LED bulbs are worth it, or if I should just go with Phillips Crystal Vision or trim 9011 tabs.
Distance, brightness and clarity are important when a deer could dart out in front of you at any time.
adurm
FL
2015 RCSB
I'd go hid. Worth the extra money and wiring imo.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Can pull headlights out, and grill, in under 10-15 minutes...very simple.
Eightd21
Eightd21
MI
NA
NA
I'm thinking about it. Is there a concensus here on which HIDs and ballast are considered "best"?
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
HID is still top dog for low beams. The simplest and easiest upgrade is LED’s in your factory fogs. They will light the entire forest in front of you without having to mess with your headlights. Upgrading your high beams to 9011 will literally turn them into spot lights!
adurm
FL
2015 RCSB
I'm a morimoto fan. Hylux is good too. Hit up jj at retroshop. He has everything you need and great customer service too.
Eightd21
Eightd21
MI
NA
NA
I've decided for now to upgrade the halogens. I've got Philips Xtreme Visions for the LBs and Philips 9011s (with the tab mod) for the HBs. Fogs I sprung for Diode Dynamics LEDs.
I'll be upgrading to HID LBs once it's warmer out.
Hemipower392
College Station, Texas
I'm missing 2 cylinders
Go HID, I had the opt7 LED's and they blow. I'm switching to HID this week after I install my new projectors
