Removing Interior Plastic
rduchateau2954
Removing interior trim plastics
I want to remove the silver plastic around the vents, radio, and steering wheel buttons and have then hydro dipped. How do I remove those pieces, especially the ones on the steering wheel?
Inside Man
N.E. Ohio
Hello, this has been done several times with great success. Head up to the search column and punch in interior removal or something along those lines with key words "interior", and "removal". You'll get a wealth of knowledge. It's been talked about so many times in the passed, it's doubtfull somebody will chime in and go over the steps.
Good luck to you and be sure to use the search bar as often as possible. You won't be disappointed with the amount of info that's already on this forum :)
Cloviz
Are you referring to the chrome pieces?
