Replace the Throttle?
Tulet
Killeen, TX
I'm getting the Trouble codes P2122, P2127, and P2138, all related to the Throttle Position Sensor. O'reilly's Auto Parts says the entire kit is $210. Is the an option to only purchase the sensor and not the entire pedal kit? This is for a 2018 RAM 1500 Laramie Longhorn 4 x 4 with a 5.7 HEMI.
NJMOPAR
Older and faster
ELizabeth, NJ
Part # MC1415 BWD throttle position sensor
$44.99 At Advanced Auto.
Partsgeek has assemblies for @ $125-$175.
indept
South Jersey
So why O'reilly's and not the dealer, have you exceeded the 5yr 60k powertrain warranty?
tron67j
Maryland
This^ With a 2018 it is not out of warranty year wise, are you over miles?
Tulet
Tulet
Killeen, TX
Replaced the pedal, and 24 hours later it was at it again. Same codes, so not the pedal. I'm thinking a kinked wire in the harness or at the throttle body intake.
Dodge 1500 4X4
Rochester, NY
How many miles on it, you have the 3/36 on it take it to the dealer, Probably a bad Throttle Body, the Pedal unit is not the throttle position sensor, its in the throttle body.
Nice looking Rig by the way!!!
