Replace window switches with auto up/down
glickgan
Colorado
HI everyone - first post. Just picked up a beautiful 07 RAM1500 and would like to replace all the window switches with auto up/down versions. Not sure if this is just a switch swap or if more is involved.
Any advice?
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
It would be pretty heavily involved. First, I don’t think any 3rd gens had the Auto-Up function, just auto down for the drivers side. At least thats all that I’ve found. (Someone correct me if I’m wrong)
Fortunately, if you were to aquire some Auto-down switches—Not the whole board, just the switches, it may be possible. While the auto switch is a bit beefier, I believe the pins line up the same, meaning you could just take off the old non-auto switches and solder some auto switches in its place AFAIK.
BUT like I said, there’s still definite sizing differences between the two. You would have to do a bit of trimming on the switch bezel to make them fit. You can see on the left that the auto switch has a larger hole
G
glickgan
Colorado
Yep, I thought it was going to me more work than it's worth. Thanks for the reply though.
