Retrofit Quads (morimoto)
jabartram
Corpus Christi, Texas
2020 Power Wagon
I have been doing alot of reading and searching and im in the middle of the painting process of my headlight pieces, i have a couple questions, in the mini h1 7 kits there are 2 gaskets (large semi coned and small flat) and 2 different style washers, are both gaskets supposed to be used?
the larger washer seems to seat the best on the outside of the reflector housing, so im guessing its the best to use?
to get the cutoff lines perfectly horizontal are there any markings in the back of the reflector to line up with the projector or is it best to temporarily install and set alignment?
