Reverse light LED upgrade
UnsatFC
Active duty NAVY
New Jersey
I just put in some Sylvania LED zevo reverse lights. Happy with the results so far. Some pictures attached.
UnsatFC
UnsatFC
Active duty NAVY
New Jersey
More pics after install outside.
blackbeautyhemi
Lewistown, PA
Did ya have to do any resistors or anything? And what bulb size is that?
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Nice. I think I have those on my ‘08. Have to remember to get some for my new 2018 when it gets here...lol.
mcaligiuri
2016 ram 1500 express crew cab
I have those also. On the express cluster I don't get a bulb out message. When I upgraded to the better instrument cluster it gave me a bulb out message.
corneileous
Podunkyville, OK
In your case, you might have to get a resistor.
Joes1500
San Antonio tx
Will these work and Is it an upgrade in the factory led tail lights ?
Thanks
seanclark1503
Seaview, Washington
6.7 Turbo Diesel
I did not have to use any resistors. I used the 921’s
They look great (bright) ! I see on the package they're rated at 6K . That's what I have on mine,different brand though. I'm sure that 6K is about as bright as can be had at this time and you've got a lifetime warranty with a reputable brand , can't beat that. Ram on !
Sent from PDX99v10
corneileous
Podunkyville, OK
I would pop one out and look at it before you bought a set. If you go to sylvanias website where UnsatFC went, they say that with projector beam headlights, you use those 7440’s and with regular headlights, it’s the 921’s.
I have no idea why what style headlight you have would dictate which backup bulb your truck uses.
UnsatFC
UnsatFC
Active duty NAVY
New Jersey
I think that if you have the projector headlights then you have the LED lights in the rear, perhaps as a package deal from the factory?
corneileous
Podunkyville, OK
Well yeah, if you have the premium headlights up front then you’re going to more than likely have the premium, LED tail lights in the back but the backup bulbs are probably still incandescent.
Even my fancy aftermarket LED tail lights I got from Anzo that were 300 bucks a pair still used the factory filament-style backup bulbs.
These are the 7440’s in regular bulbs.
Sir John
Buffalo, NY
2016 1500 Rebel "Mopar 16" Special Edition
Sent from PDX99v10
Just so it's clear....a higher bulb color temperature (i.e. 6000K) does not equal "brighter" light (lumens).
Rgesse
