Reverse lights
Alfonsio
2010 Big Horn Quad Cab 4x4
I'm looking to change out my stock reverse bulbs for something brighter.
Any suggestions for a direct "plug & play" without using resistors?
Thanks in advance for your help.
Stangshcky12
Oshkosh, WI
5.9 Cummins
Reverse lights aren't in the canbus so any led bulb will work
Retro solutions has a bulb specifically for 4th gen tails
LB3711
Trumbull, CT
3.6L V6
They are good. I think I had mine over a year and no issues
Sent from my Samsung Galaxy S4 using Tapatalk
emjohn4
2009-2012's the Retro LED's are great.
2013+ OEM LED tails....the Retro LED's are...just OK.
For the 2013+ OEM LED tails, the reverse lights were much better from the factory than the 2009-2012's.
Stangshcky12
Oshkosh, WI
5.9 Cummins
Can't say I noticed a difference in the stock bulbs from my buddies '13 Laramie compared to my dad's '11
What has changed? Do you know if it's still the same bulb in the LED tails, I was just talking to my buddy about changing his out
emjohn4
I noticed a giant difference between my standard OEM tail light reverse lights and my '13+ OEM LED tail lights I installed.
Standard tail lights use a 921 bulb as the reverse light, and the '13+ OEM LED tails use a 7440 (?) type bulb. Much brighter.
garyw123
Maryland
I also have the retro solutions CREE LED's and love them….tons more light at night very helpful backing into dark areas….I can take some pics tonight if you like...
fivehead1
Hey guys,
I ordered the Retro Solution LED's mentioned above. When I put them in the connectors, are the LED's supposed to face out to the side, or in towards the reflective silver in the housing?
Thanks
fivehead1
Crap. I faced them in, since I didn't think they should be pointing 90 degrees to each side of the truck.
Sent from my DROIDX using Tapatalk 2
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
they shouldn't........they should point right out the back. They ARE side specific.........so keep that in mind!
fivehead1
I didn't realize that. I'll try swapping sides and see if it helps.
Thanks
fivehead1
Yup, the old switcharoo worked. Thanks, guys!
Sent from my SM-T210 using Tapatalk
joshhhh
