Right rear turn signal and brake light out
rydec
New Jersey
2015 Ram 2500 not getting power to the bulb for the right rear brake and turn signal. All of the other lights work including the trailer lights and third brake light, ground is good no issues at the wire connecters or damage to wire in the harness. Not the TIPM. Any advise on what the problem could be. Not LED lights.
Atcer2018
Virginia
Have you tested the wiring before the socket? The sockets go bad on our trucks and they are replaceable. From experience only use the OEM sockets as aftermarket’s tend to set bulb out messages.
R
rydec
New Jersey
Yes I tested the wire before the socket and also tried the good socket from the driver side.
Atcer2018
Virginia
Do the 4 way hazard flashers work on the right rear? I ask because trying to determine if they are receiving any signal. I believe there is a fuse in the power distribution box under the hood but I have a 1500 and my fuses are labeled left side and right side. If your right front turn signal is working it’s probably not the fuse. Just to cover all bases have you tried a new bulb?
**never mind the bulb comment as I see in your original post that there is no power to the right rear.
I’d still try the hazard flashers as in my limited experience no power on wires with continuity and good ground leads back to the TIPM.
Bchurch91
New jersey
Hey guys, I found the solution. For me, it was the plug underneath the driver door that connects to the ecm or whatever. The ground and rear taillight pins were corroded into nothing. I just cut those two wires off the plug and splice them back together
Mmrsntx1
houston, tx
Hey would you be able to tell us the color of the wire you spliced? and I guess if you can circle which pin it was?
TMFMK
