Rim And Bolt Size
argray90
NW Burbs, IL
I just want to confirm that 17x9 rims will fit my truck it is a 2012 dodge ram 1500? I cannot remember the lug or bolt pattern any help there?
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
Bolt pattern is 5x5.5
Just a reminder. The 2012 wheel studs use a 14mm x 1.5 lug nut. Make sure you get the right ones if your not going to use the factory lug nuts.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I used 17x9 OEM rims with no issues.
argray90
argray90
NW Burbs, IL
Ok I was just told that the 17x9 rims would not fit with the brakes and I prefer the 17's just because all around its cheaper.
SILVER_BULLET
they do fit i have a pair i use for the track that are 17x9
Rock$tar
Newfoundland, Canada
Cummins 6.7L
outdoorsmen / SLT / ST come with factory 17s.
I have 17x8.5 MR301s on my truck and they clear with zero issue. There not even close to the brakes to be honest.
argray90
argray90
NW Burbs, IL
Ok great thanks everyone I thought I had 17x9s stock but I was told there was an issue with them fitting and I just wanted to be sure so I didn't have to spend more on 18's. Thanks.
BlownGP
Houston/Baton Rouge
They should fit, what is the offset on the 17x9s you have?
argray90
argray90
NW Burbs, IL
Not sure what the offset is on my stock rims currently just running the stock rims.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
17 should fit but they will be the smallest because of calipers. I have seen many Rams with 17" rims.
$miley
