Rim Offset
daveray9
I have a 2012 w/ chrome clad and am looking to buy the RIMs from the newer 4th gen Rams that are blacked out, but I am reading they are 18mm offset and mine is 19mm.
I have new BFGoodrich KO2s installed and would want to keep these, they are stock size of 275/60/20. Does the offset matter or change the tire size by 1mm?
A05GSHO
Southeast WI
Your tires on the 18mm will be just fine, only a 1mm difference.
Maligator
Hem 5.7
You probably wouldn't even notice a 1mm difference. FOR example my fuels are a 0 (zero) offset and stick out from my fender about 3/4" of an inch.
So the difference between +18 and +19 would mean the wheel would be offset 1mm further toward the center of the truck. So basically a hair over 1/32" of an inch.
daveray9
daveray9
Thanks guys. Figured as much just wanted some feedback.
Sent from my SM-G920V using Tapatalk
quietpeen
2021 TRX
Hellcat
the offset is not 18 mm on the 20x9 black sport wheels its 19.05mm
MADDOG
Living in a Firepit
6.4L HEMI
