RKSport hood
crazy_luck
Minnesota
I can't speak for those hoods myself, but I know in the past the ones for the Charger/Magnum/300C from RkSport have had bad fitment issues that have required more cost and time to correct than any of the other hoods out there.
Statcher1
Kentucky
They look good. It would be nice if the fit like factory.
RTS001
New Orleans, LA
I am considering this hood as well. It looks more factory even with the scoop. But I have yet to find much info on fitment for the ram:
Doc1609
Missouri
I had one on my old tundra and it fit well. I had to do some minor adjusting, but nothing terrible.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
too bad its designed for factory style CAI… and not the vararam.
cbo
what about an S&B intake? those are a box style and are mounted in the stock location, correct?
Doc1609
Missouri
Not sure what fits for the rams and these hoods, but I had an airaid on the tundra, which worked with the induction of the hood.
InspectGWS
Houston, TX
2014 JEEP GC SRT8
6.4L HEMI
Is the RKSport hood fiberglass? If so it will weigh a ton...
VIS-Racing-09DGRAM2DSRT-010C is a carbon fiber hood...and a much better product.
Dubstep Shep
Houston
2014 R/T
The idea of piping air through a hood, which I guarantee is EXTREMELY restricted, and them back through a CAI is silly.
Dubstep Shep
Houston
2014 R/T
Yeah, it's not a big deal
Don't get me wrong, a hood intake is a FANTASTIC improvement over the normal intake method, but only if you pipe it straight into the motor, like with a Vararam. But good luck finding a hood like that.
UsAndaTruck
Huntington Beach, CA
I've been curious about this too. Do you need a hood scoop with the Veraram intake? It is on my short list of upgrades, but if I need to pair it with a scoop, it might have to wait a bit longer... also, if the general idea is that this hood isn't that great, what IS a great scooped hood??
Dubstep Shep
Houston
2014 R/T
No, you don't need a hood scoop. It would just work better with one
WadXpress
HEMI
It takes the air from the grill. so no you dont need a hood scoop
Doc1609
Missouri
I don't think the veraram works with anything but an oem hood
Doc1609
Missouri
This is from vararam's website-
• The system uses the OEM hood, R/T and or aftermarket hoods are not required. The system draws air from the high pressure zone between the upper core support and the underside of the hood.
