Rock guards
Ferd
High Point NC
Hemi Baby!
Hello all. I need a little help removing the factory rock guards from my 17 Ram to install mud guards. I tried removing the rear rock guard and that little screw that holds the rear portion kicked my butt! I couldn't get to where I could get a good look at it, but the screws seem to thread into some sort of plastic nut and they will not screw out. The instructions only say to remove the rock guards but nothing about them being such a pia! Anyone know how to remove these blasted screws? Thanks!
kurek
Northwest
I don't have much memory of doing that job because it didn't give me any trouble, but if you're not able to get the screws to push themselves out from the nylon nuts can you give them a little tension by pulling on the rock guard while you turn the screwdriver - putting a little tension on the back side of the screw head?
ram1500rsm
Trabuco Canyon, CA
Hit them with a rock couple of times and like magic they'll fall off. They should be called bug guards.
