so i had some time to crawl under my truck and look everything over... i noticed that the bottom of my frame is pretty much level if not higher than the bottom of the body. so that would make it nearly impossible to run these DYI sliders. i would almost have to have extended mounts to drop the slider leg low enough to not his the cab. i could probably do this if i did custom mounts but i dont think this will be worth it.
i may end up going with either the ICI magnum steps, go rhino steps, or NFAB just to keep a more aggressive look.
