Rockford Fosgate
Picton
Houston, Texas
2015 - 1500 Express CC 4x2
Can anyone confirm is those 6x9 Rockford Fosgate Punch series speakers (PN#: P1462) fit in an Express crew cab with the 6 speaker 5.0 head unit? 2015 truck. They worked in a 2013 SLT 6 speaker with 8.4a unit and no woofer.
Crutchfield says they won't fit on the front doors because they're too deep. I guess they changed something in the door?
WilliamS
Tampa FL
P1462 is a 4x6. The p1692 is a 6x9. They will fit with some convincing. I didnt have to cut anything but they were a squeeze in there and the screws were a pain to get in there but I was able to force them in.
Picton
Picton
Houston, Texas
Awesome! Thanks for confirming William. Yeah sorry for the wrong PN there.
WilliamS
Tampa FL
You will need to really work the screws on there, you best off with a small spacer, but you can make them fit! If you were in Tampa Id give you the set I took out last month.
15BLACKRAM
i got mine in with no issues.. edit... oh wait... those whent in the back doors.. the 6.75 kits went in the front.
Picton
Picton
Houston, Texas
Man...are we sure these can fit into the front doors on a 2015? I'm in the middle of the install...rain delayed...but I don't see how those are going to fit. Even if I can get a screw in, I won't be able to get ALL of the screws in. I wonder if they changed anything from 2013/2014 to 2015?
On the rear doors, the kickers worked...not all the mounting holes line up though. I was able to get 2 screws in opposing corners. They're tight...I'll probably be ok without the other 2 screws right?
Just frustrating when Crutchfield says they'll fit.
OC455
Central NY
I just put in some Hifonics 6x9's in front and rear doors. I used 6mm spacers in the front and rear doors because the metal basket/frame of the speakers are larger around than the OEM 6x9's.
I started the screws one at a time to make sure they were started in the holes and then tightened them down cross wise from each other until they're flush.
4d6n2
North Texas
Im in Tampa!
Ghstrdr95
